CONNECT feedback portal
Product Streams
Created on Aug 18, 2022
Missing Units of Measure
If CONNECT data services (formerly AVEVA Data Hub) is missing units of measure that you use and need for your data, please vote for this idea AND add a comment to this idea specifying what the missing UOMs are. Previously added UOMs September 2021: https://datahub.feedback.aveva.com/ideas/DHDM-I-22
  • Albis Durand
    Jun 30, 2026
    These are units of measurement requested by our coal mining customer
    tonne per hour (t/h)
    gram per tonne (g/t)
    megajoule per kilogram (MJ/kg)
    milliliter per minute (mL/min)
  • Daniel Huang
    Jul 8, 2025
    We need the following UOM:
    • kVA (kilo-volt-ampere) is the measure of apparent power, representing the total power used in a system.
    • kVAR (Kilo-Volt-Amperes Reactive) is the measure of reactive power required by inductive loads.
  • Fabio Dani
    Nov 5, 2024
    One more unit of measure that is missing is a speed: m/min
    This is for one lighthouse where there's a cutting process and that is measured as meters per minute.
  • Fabio Dani
    Apr 29, 2024
    Here is another list of units of measure that are needed for a Lighthouse Engagement
    pH
    Kg/day
    Kg/h
    Mg/L
    Lb/day - Pound per day
    Gal/day - Gallon per day
    Liter per day L/d
    Liter per minute L/Min
    dBm
    NTU and FNU - Turbidity measure (https://en.wikipedia.org/wiki/Turbidity)
    W/(m²-K) - heat transfer coefficient
    tonne/hr
    Kgal/hour
    Kgal/min
    Cubic meter per day
    MPY - Mils penetration per year - corrosion rate
    LSI - Langelier Saturation Index
  • Admin
    Todd Brown
    Jan 26, 2023
    Another list of missing UOMs from another customer:
    • ft3/h
    • gal/day (gpd)
    • kg/TDS
    • l/h
    • l/min
    • lb/day
    • m3/day
    • t/h
    • Be (baume)
    • Bushel
  • Fabio Dani
    Dec 16, 2022
    We are trying to change the Units of measure for one specific application and we are missing the following units:
    BarA - Pressure - Absolute Pressure
    kg/h - mass flow (Does not exist only Kg/s exists)
    nm3/h - Normal cubic meter per hour, this is normalized to 0 C and 1 atm. https://iadclexicon.org/normal-cubic-metres-per-hour-nm3h/
    mg/nm3 - concentration - miligrams per normal cubic meter https://www.convertunits.com/info/mg/Nm3
    MJ/nm3 - Megajoules per normal cubic meter this is normalized to 0 C and 1 atm.
    kj/h - Energy - kilojoule per hour
    kj/hrm2 - kilojoule per hour meter square
    g/m3 - Gram per cubic meter
    mm/s - speed - used for vibration
  • +3
