CONNECT feedback portal
Status Completed
Product Streams
Created on Aug 18, 2022
Missing Units of Measure (UOM) 2021
If OCS is missing units of measure that you use and need for your data, please vote for this idea AND add a comment to this idea specifying what the missing UOMs are.
    Aug 18, 2022
    We are happy to announce that new Units of Measure are now available in OCS: millimeter per square second (mm/s2) meter per square second (m/s2) Cubic feet per minute (ft3/min) deciSiemens per meter (dS/m) Siemens per meter (S/m) Microsiemens per Centimeter (µS/cm) microgram per cubic meter (µg/m3) Count per Liter (Count/L) milliWatt-hour (mWh) Watt-hours per mile (Wh/mi) inverse centimeter (cm-1) inverse meter (m-1) Lux (Lx) Watt per square meter (W/m2) nanometer (nm) micrometer (μm) hectoPascals (hPa) millibar (mbar) Newton meter (Nm) The following UOMs were requested by customers but were not added at this time: pH --> not a unit; please put this in the stream name / description Volumetric Water Content (VWC - %) --> please use % as the UOM and include VWC in the stream name / description USD --> currency not supported at this time due to it's value changing over time Euro --> currency not supported at this time due to it's value changing over time USD per mega watt hours --> currency not supported at this time due to it's value changing over time USD per hour --> currency not supported at this time due to it's value changing over time Didn't make it into our backlog in time for this release (will move to another idea): Mcf/d = thousand cubic foot per day (we have cf/d) --- volume flow rate Ft.lbf = foot pound --- energy 1/min = rate --- rate (we don’t have any “Rate” uoms like this) Gn = acceleration compared to gravity constant --- acceleration micron(micrometre- μm) -- 1×10−6 m
  • Patrick Davis
    Apr 3, 2024
    Please add m3/d (cubic meters per day) and km3/d (thousand cubic meters per day) volume rates UoMs. These are used in Unified Supply Chain.
    Sep 24, 2023
    As per instruction received from Mario Coelho this is a request from Apollo Energy Analytics, we are submitting the request to add new units of measurements relevant or used abundantly in SOLAR power\energy domain.
    VA - Volt-Ampère
    VAr - Volt-Ampère reactive
    VArh- Volt-Ampère Hour reactive
    W/Wp - Watt/Watt peak
    Wh/m^2 - Watt Hour/Meter square
    Wh/Wp - Watt Hour/Watt peak
    DEGREE CELSIUS^2 - DegC square
    Aug 18, 2022
    These are only the initial UoMs that we found that are not in supported UoM list in OCS. There could be more depending on the device types and their attributes. Thanks.
    Aug 18, 2022
    As an OCS user in the agricultural industry, I would like to add these Units of Measure so that we can better support the agricultural data we are gathering: Solar Irradiance in W/m^2 Atmospheric Pressing in hectoPascals Volumetric Water Content as a % ratio Electical Conductivity as deciSiemens/m Concentration as pH density as microgram per m^3
    Aug 18, 2022
    Airflow: ft3/min (+ other time durations?)
    Aug 18, 2022
    PowerFlex EV Charger data: mWh (milliWatt-hour) Wh/mi (Watt-hours per mile)
    Aug 18, 2022
    Building Airflow: cubic feet / min (ft3/min)
    Aug 18, 2022
    hectopascal hPA
    Aug 18, 2022
    $/MWh $ $/h mm/s2 Nm mbar
    Aug 18, 2022
    lux (lx) counts/Liter (counts/L) Count/L Used for Air Quality: the sensor units that I am building have an air quality sensor that reads particle counts per Liter at various different particle sizes
    Aug 18, 2022
    Aug 18, 2022
