CONNECT feedback portal
Status Completed
Product PI to CONNECT
Created on Aug 18, 2022
Save PI Point Transfer List to easily rebuild transfer query
Having to redefine the Pi point transfer list manually every time is inconvenient. For example, it currently takes 5 different queries for me to build my list, and this last time I forgot one. It would be nice if somehow you could save and reference a previous list of pi points or the application remembers what has already been included in a past transfer. It's really common that you might only need to add a few streams to the existing pi point transfer list. If you could save a list of previous transfers then add the new query for new data, this alleviates having to build the list from scratch each time. Some way to alleviate having to rebuild these transfer lists manually each time would be appreciated.
    Aug 18, 2022
    We are planning to add support to edit an existing transfer in an upcoming release. If you would like to discuss your use cases and requirements around this feature, please reach out!
  • Admin
    Janelle Minich
    Apr 27, 2023
    PI to Data Hub allows you to export the transfer definition as a .CSV file so you can refer to it later.
    Additionally, if you have configured an AF database, PI to Data Hub now supports AF Elements. Any AF element included in your transfer will automatically create and transfer the associated PI Points and AF element attributes to AVEVA Data Hub.
