CONNECT feedback portal
Categories General
Created by Mike Horrocks
Created on Jul 20, 2023
Permit non-protected references
The secrets references is a very useful addition but they are only permitted for "protected" parameters. It would be useful to also create references for non-protected parameters.
Using references for non-protected parameters would help with creating configuration templates for adapters with standard naming, filters, etc. but allow them to be used to connect to different data sources/end points/etc. when deployed to adapters with different secrets.
    Jul 11, 2026
    What is the advantage of this over saving and using a template configuration JSON file that contains all of the configuration that will not change between different AVEVA Adapter instances, components, data sources, etc.?
