CONNECT feedback portal
112 VOTE
Status Future consideration
Created on Aug 16, 2022
PI Adapter for OPC UA should be able to write outputs to the OPC UA Server
The PI Adapter should be able to create a data pipe listener on certain streams (unsolicited reads) that would trigger the writes back to the OPC UA Server. This is useful when providing set points to the equipment without the need of establishing a second (DA to UA) data flow in parallel.
    May 11, 2026
    Voted. In my opinion its a must to have feature!
    Sep 11, 2025
    {"children":[{"type":"paragraph","children":[{"text":"This is a must to have closed loop or intervention based systems"}]},{"type":"paragraph","children":[{"text":""}]}]}
    Dec 6, 2024
    In the industry the demand for secure & native OPC UA integration is increasing.
    Ability to make PI data available through OPC UA protocol is certainly something what should be addressed by AVEVA.
    Either an PI OPC UA Server to allow connected applications to pull PI data using OPC UA, or, as suggested here, to have an Adapter to push data into external OPC UA Servers
    Complexity might be the fact that Adapters are not designed to read from their OMF endpoints.
    Eagerly waiting to understand the AVEVA roadmap. Usage of DA/UA wrappers should only be a workaround
    Sep 16, 2024
    When is Aveva considering implementing this feature ?
    Oct 20, 2023
    this is an opc ua specific duplicate of this one
    https://pisystem.feedback.aveva.com/ideas/PIADAPTERS-I-26
    Apr 26, 2023
    Voted. I can certainly see the use case, but there must also be a Read Only adapter which does not contain the write code. Same logic as the current Read Only interface(s).
    Mar 22, 2023
    To write the value back to equipment is for most of enterprise customers essential, especially if production is orientated to MES workflows. Sadly that for suitable replacement for most used classic (old) interfaces, like OPC DA, there is still no proper solution.
    Nov 16, 2022
    Yes Ability to write back to source OPC UA is essential.
    Aug 16, 2022
    We need this feature to replace our old OPC DA Interfaces. Otherwise we wont be able to switch to PI Adapters.
    Aug 16, 2022
    Ability to write back is essential, frustrated we are still waiting for this to be actioned.
  • +12
