Are there any plans to implement this feature? (Maybe as Blob - PI-Point in DataArchive?)
Many digital tags in Honeywell Experion OPC UA are "EnumValueType". It is important for us to read these data.
This is a must have, there is data presented in string arrays that we require access to. Its hard to believe that I may have to revert to an old OPC DA server and the OPC DA interface just to get at some of the required data. In my first foray into the OPC DA adapter I discovered the vendor puts run id, product, etc into a string array. This is absolutely required for contextualizing run data.
When upvoting this idea, could you please specify what type of arrays you want to capture in PI and how you will be consuming it?
Would storing each item in the array in a separate PI Point work for your use case? Why or why not?
What dimension are the arrays you would want to capture (1-D, 2-D, n-D)? https://reference.opcfoundation.org/v104/Core/docs/Part8/5.3.2/
https://reference.opcfoundation.org/v104/Core/docs/Part8/5.3.4/#5.3.4.3
Example of multi-dimensional array: CubeItemType representing a cube of values like a spatial particle distribution
What tool would you use to consume the array data stored in PI Server / ADH? Native PI tools (PI Vision) or external reporting / visualization tools?
