CONNECT feedback portal
Status Future consideration
Categories General
Created on Aug 16, 2022
Provide a streamlined way to rename streams and push the changes to the endpoint
The current process forces the user to modify the adapter configuration (DataSource for the prefix, DataSelection for the stream name) and the endpoint (PIDA, OCS). The adapter should support modifying directly the stream name and push those changes to the endpoint. This would be in line with how some PI Connectors will automatically edit the destination PI Points when it is renamed from the DCM
    Sep 9, 2022
    In case of a PIDA endpoint, it would be more streamlined to manage the renaming in PIDA and push the changes to the Adapter.
    How do we know which Adapter to push to? Pointsource + Location1
