CONNECT feedback portal
Status Already exists
Created on Aug 16, 2022
Specific debug log levels to troubleshoot specific issues
Similar to PI Interfaces (/DB for opcint), adapters should allow setting some additional debugging to troubleshoot specific issues, instead of only allowing a general LogLevel (Information, Trace, Warning, etc.) This would allow for more granular logging instead of either having no useful information or so much information that it is very difficult to parse and determine what an issue is. Examples: Additional debugging around discovery / browsing Additional debugging to record data flowing or a specific stream / nodeid Additional debugging listing all items that were added to a subscription Additional debugging around history recovery
    Oct 16, 2023
    Logging should also be able to be much more detailed. For trace logging on the data source I want to see all the SDK calls being made by the adapter. For example compare with the trace logs of UaExpert.
    This may or may not be super useful for the end users, but I feel certain that this very low level detail can help the AVEVA people to diagnose issues in the field.
  • Admin
    Jiyeon Hwang
    May 9, 2023
    Thank you for your input. There are two additional logging levels you can set with AVEVA Adapters: Debug and Trace. Debug level can help with troubleshooting data flow issues, and Trace will give you the most detailed messages with sensitive application data. Please refer to our product documentation to see more information around these Log Levels.
