CONNECT feedback portal
Status Tell us more
Categories General
Created on Aug 16, 2022
View PI Adapter log files via REST calls
We would like to be able to see the adapter log files via REST calls. Going to the machine itself to view is problematic because of remoting into the router and then going into the container to view. I think in a lot of containerized situations a REST call access would be better.
  • Admin
    Jiyeon Hwang
    May 9, 2023
    Thank you for your feedback. We have recently introduced AVEVA Edge Management, an offering available via AVEVA Data Hub that allows you to remotely deploy edge modules (including adapters) for remote manageability. We are also working on a software management service through AVEVA Data Hub that allows you to manage all your deployments (both standalone and module-based installations of adapters), allowing you to get access to message logs and other health information remotely. Usage of Edge Management and software management does not mean you need to use AVEVA Data Hub as a data endpoint. If this is not suitable for your needs, please let us know what other constraints you have in terms of using our offerings in the comments below.
