CONNECT feedback portal
Status Evaluating
Created on Jul 30, 2026
Adapter Configuration Utility enhancements
Great the ACU is out and helps a lot with initial configuration of PI Adapter. Tested PI Adapter for OPC UA so far. I know it is version 1.0 so hopefully shttps://aveva.aha.io/ideas/idea_users/7158109947785273550oon there will be new versions with added functionality which I am currently missing:
  1. Missing Component ID STOP and START command. Useful for initial testing and configuration and troubleshooting
  2. The Data selection is just a read only table where you need to export file into CSV or JSON and import it back. I would be great to have option to write directly to the cells like for Custom Stream ID or if I will define several Schedules, then in the Schedule column there should be a drop-down menu in each row to assign the selected schedule. Of course for bulk edits better to process CSV in MS Excel, but for a few edits, the GUI would be perfect.
  3. For PI Adapter for OPC UA at least more specific functions, like request history recovery and submitting the intervals. This was a downside of PI Connector not to have an option to do a customized HR.
  4. The Log section is only showing ACU log, the OmfEgress, Component logs still has to be opened in the Notepad or similar.
I know the 1.0 version should be more for quick configuration and specific commands were not prioritized, but we have two big projects coming up where we would use PI Adapters instead of PI Connectors. Namely because of HA support for both server-level and adapter-level failovers and having OMF endpoint behind NLB. Current options are not perfect, but as PI Connectors to be mostly in the maintenance mode this should get better with newer versions.
    Aug 3, 2026
    Hey Ondřej - thank you for your feedback on using the new AVEVA Adapter Configuration utility - it is much appreciated! I am going to create individual ideas for each of the enumerated items you have raised in your post. This will help others to upvote and help AVEVA prioritise in a more granular fashion. Please feel free to upvote these new ideas and add any additional comments or characterisations in each thread as you see fit!
