CONNECT feedback portal
Created by Daniel Lopez
Created on Mar 30, 2026
Allow session persistence to support true QoS 2 data collection and backfill of events after a data source disconnection
It appears that regarding Session Persistence (persistent vs clean session), the Adapter hardcodes setting the Clean Session Flag for the generic data source (Sparkplug doesn’t QoS 2 nor session persistence) to true.
This should be a user-defined parameter for the generic data source in the Adapter. Without session persistence, it means that all messages sent to the broker while the Adapter is disconnected will be not be retrieved upon reconnection. If it were user defined, and a site had a broker that supports session persistence, it would allow that when the Adapter reconnects to its persistent session, all subscriptions are reinstated and all stored messages are sent to the client. This also allows for some history recovery capabilities.
When looking at other vendors, almost all of them support this. The library that is likely being used in the Adapter does support setting up this parameter, but it appears that it is simply hard-coded to be cleanSession = true. Not having this as a user selectable parameter means that this Adapter may not provide the degree of robust, fault-tolerant data collection that a site needs.
This has been confirmed as a practical requirement by a notable user group within oil and gas, both in September 2022 and March 2026.
