CONNECT feedback portal
Created on Mar 11, 2024
Please add a feature for the OPC UA adapter to enable the adapter to only store values with a good status or rather filtering out bad values
When receiving bad values from the OPC UA Server to the adapter there is no option to filter out bad values. So these values get stored in the Data Archive and are causing problems with analyses (e.g. expression or Event Frame generation). At the moment the only way to solve this problem is a workaround where you have to create analyses in Asset Framework filtering out the bad values and mapping the output to a new PI Tag. This solution is technically terrible and it would be really helpful to be able to filter out the values beforehand.
    Aug 30, 2025
    We also have cases where templates used to create some nodes in OPC server include tags that are only sometimes used across multiple instances. When not used, there is an OPC quality flag on these values and we don't need to store those values into the archive. In fact, we may not even need to store that part of the structure/node. More ability to query/filter during adapter configuration (data selection) and data filtering (storage) options would be very useful.
