CONNECT feedback portal
Created on Mar 8, 2024
PI Adapter for OPC UA should preiodically retry to subscribe to each node for which subscription failed at startup
Currently the PI Adapter for OPC UA tries to subscribe to all the OPC UA nodes configured in the Data Selection configuration at startup.
However, when as issue occurs during the subscription to an OPC UA node, that node will not be included in data collection and will be basically ignored.
This is a serious issue when your plant is in a startup and the status of the different nodes toggle from Good to Bad on a regular basis.
The only ways to retry subscription to all the OPC UA nodes is to restart the PI Adapter or to update the Data Selection configuration.
Ideally, a parameter should allow us to configure at which frequency the PI Adapter retries to subscribe to nodes configured in the Data Selection for which subscription failed at startup.
    Apr 3, 2025
    This is important because the failure to add a node is not only related to a bad config in the adapter, but can also happen if the upstream device is not giving data to the OPC UA server.
