CONNECT feedback portal
Product Streams
Created by Jeff Branfield
Created on Feb 8, 2024
Simple file import through AVEVA Data Hub Portal
Challenge: Customers would like to have the possibility to do a simple import of a CSV, JSON, XML, Excel file by uploading it to the Data Hub portal and store the data into Streams without taking the efforts on installing and configuring an instance of a PI Adapter for Structured Data Files or create a python script for that as it is just a one-time import of the file.
Solution: Provide a feature under Data Management which then takes the user through a wizard to map content of the data file to a stream and then push the data up into SDS
  • Max McKay
    Jun 19, 2025
    As a data analyst, I want to include a data set as a 1-time only, which does not justify the time investment in and does not depend on having a server and admin priviliges to set up.
    This is especially true in cases where we want to test analytics models, and to train a ML model for quality predictions as the quality data comes in with a delay, and is often stored into a different system.
    This is also very useful for demos, POC.
