CONNECT feedback portal
Categories General
Created on Jul 21, 2023
Provide possibility to filter streams in a REST API call based on their origin
Challenge: A customer (industrial operator) is sharing data with an equipment vendor on a specific equipment through AVEVA Data Hub Communities. The equipment vendor reads data via REST API using a (python) script to process it for further data analysis. The result of the analysis is stored as streams in the vendor's tenant of AVEVA Data Hub and shared back through the community.
Problem: When querying all streams in the community the script is finding all streams within the community but when processing data there need to be special treatments because it needs to make a distinction how to access data for remote streams and for local streams.
Solution: provide an option to REST API calls on a stream search within a community to select the origin of the streams. Like if it should display all streams within the community or own streams only or remote streams only. This would simplify how scripts and queries can designed.
