CONNECT feedback portal
Product Streams
Categories Metadata Rules
Created on Aug 18, 2022
Add a Stream Tag Rule engine similar to the Metadata Rule or Asset Rule engines
It can be helpful for a Rule engine to automatically apply a specific stream tag to newly created streams based on similar workflows as the metadata rules. Stream tags are preferable over metadata in certain scenarios (where the value doesn't need to be named, and multiple values may be needed for the same topic), and it would be helpful to create the tag automatically for the streams that follow a certain pattern or patterns. This pattern may not be sufficient for the entire list, so replacing the query syntax of the stream tag with the pattern that would be used by the stream tag rule engine may not be sufficient, but would cover enough of the streams to make the rule worth creating.
