CONNECT feedback portal
Product Assets
Categories Asset Rules
Created on Aug 18, 2022
Improve Asset Rule Flexibility - Accommodate Stream with Segments with two purposes / overlapping token strings
The ability to derive multiple tokens from the same overlapping strings. Requirement: From the example stream name “PIDAHou_Flow.PV”, we need to be able to derive the following asset ID and metadata information. Asset ID: ”PIDAHou” Asset property “Measurement”: “Flow.PV” Value of Asset metadata “Location” : “Houston” (mapped val from Hou) Value of Asset Metadata “Product” : “PI Data Archive” Solution Option 1: Support: Overlapping tokenization (Note that Token1, Token3 and Token4 has overlapping string parts of the stream name). Token1: string before the first “_”, and use this token to express Asset ID : {Token1} Token2: string after the first “_”, and use this token for Measurement property Token3: Three letter string prior to the first “_” with the mappings {“HOU”:”HOUSTON”, “DAL”:”Dallas”}. use this token to assign to the metadata Location Token4: Two letter string starting at 3rd position with the mappings {“DA” : ”Data Archive”, “AF” : “Asset Framework”}. Use this token to assign the metadata Product Use the values of these tokens to extract required info as follows Asset ID={Token1} Measurement = {Token2} Location={Token3} Product={Token2} Solution Option2: Use both raw unmapped token as well as mapped value of a token Token1: First Two letter as literals Token2: Two letter string starting at 3rd position with the mappings {“DA” : ”Data Archive”, “AF” : “Asset Framework”} Token3: Three letter string prior to the first “_” with the mappings {“HOU”:”HOUSTON”, “DAL”:”Dallas”}. Token4: string after the first “_”, and use this token for Measurement property Use the values of these tokens to extract required info as follows Asset ID={Token1}{Raw unmapped value of Token2}{Raw unmapped value of Token3} Measurement = {Token4} Location={Token3} Product={Token2}
