CONNECT feedback portal
Product Streams
Categories Metadata Rules
Created on Mar 29, 2024
Improve Stream Meta Data rules
Some potential improvements to Stream Meta Data rules:
- Improve on how to 'filter' which streams are associated to a particular rule. One way this is possible today is by the use of the String Literal, but that then means I cannot use the same portion of Stream Name to build a meta data.
- Allow for 'hard-coded' meta data to be added, independent of a stream name 'portion'.
- Allow for use of both Stream Name or Stream ID to build meta data rules.
Overall, if a similar approach to Asset rules (Tokens) were used for stream meta data rules, many if not all these potential enhancements would be addressed as a consequence. Moreover, this would also simplify the user learning curve to build rules (Stream meta data or asset rules). As part of my role, I currently support the use of DataHub/Connected Data Services for different types of partners (including OEMs, machine builders, etc), these 2 functionalities are very powerful for their use cases, so aligning/improving on it would be a great selling point for these partners.
