CONNECT feedback portal
Status Completed
Product Assets
Categories Asset Rules
Create Custom-Defined Patterns for Creating Assets from Stream Names
Ability to create user-defined patterns that can be parsed from the stream name to create Assets, Asset Attributes, & Asset Measurements. Currently the service uses delimiters to aid in the construction of a pattern. This would help customer create and manage Assets in Bulk. For example, a stream name with B.1234.Temp can be deconstructed into Assets: Boiler 1234 with related data such as Temperature referencing the stream.
    Rule builder is now available in OCS to parse stream naming patterns into stream metadata or asset metadata & properties.
    Ability to create user-defined patterns that can be parsed from the stream name to add context. Currently the service uses delimiters to aid in the construction of a pattern. For example, a stream name with B1234 can be deconstructed into equipment: Boiler and equipment ID: 1234
