CONNECT feedback portal
Product Data Views
Categories General
Created by Clement Dekeyser
Created on Aug 3, 2026
Separate columns for summaries in narrow, asset-based data view
As a data scientist, I like the narrow data view format because the schema does not change when properties are added, modified or removed.
However, I also need to perform consistency checks over my dataset. For example, I need to compute range over standard deviation or check that min < mean < max.
I need to perform these checks over all properties, so it would be easier if the summaries (range, min, mean, max...) were in separate columns, while still keeping the narrow format. Here would be the resulting format:
Timestamp | Asset | Value | Min | Max | Stdev | ...
Currently, when creating a data view with an asset-based query, the narrow format will send all raw & summarized values to a single Value column.
